Headlight switch harness wire problem
gettygatz4life
Bronx ny
01 Tahoe having problem with high beam low beam dash board light climate control light all not working check all the fuse everything okay in that department I had 4 extra headlight switch laying around just in case because you no these truck come with problems but anyways I tried the other headlight switch to see if this will fix the problem to no avail nothing so right now my main concern is the harness wires I need to know what each 7 pin wires are for so I can put a new wire harness on been looking for a diagram or a picture telling which wire do what like which wire is ground 12v high beam etc if you can help please get back to ASAP thanks
Sent from my SM-N900V using Tapatalk
gettygatz4life
gettygatz4life
Bronx ny
gettygatz4life
gettygatz4life
Bronx ny
I see nobody on here like to talk about headlights harness pigtail wire problem
05Single
afraid of the dark
Sometimes you gotta ask twice lol. So there's no lights but the buttons and switches are working ? sorry it's hard to follow with one long sentence.
gettygatz4life
gettygatz4life
Bronx ny
Thank you bro for taking the time to answer some questions for me OK head lights climate control and Custer don't light up I think the harness is bad and need to be replaced the color of the wires I need to know what each one of them do just in case I don't find the same color on the new wires that all
05Single
afraid of the dark
Did they work before ? if not did they all go out at once? are your door switches lit up?
I'm not sure if it's a whole wire harness. I would assume each have they're own circuit.
I've never dug deep into this kind of thing but I know these lights go out all the time. most of my dash is out and my whole ac and headlight switch is out.
I'm waiting for $$ so I can send them to @ScottyBoy , for he is the master of interior lighting and harness the knowledge of harnesses lol
Hopefully he can chime in with his professional opinion and maybe some ideas.
Sorry I don't have an exact answer.
gettygatz4life
gettygatz4life
Bronx ny
Thanks for your opinion that let me know I'm not by myself on this one I guess I'm calling scottyboy out how do I reach him in here
ScottyBoy
Shreveport, La
I'm a bit confused as to what the exact problem is. Is it ONLY the dash backlights that are not working? The headlight switch, cluster, and AC control panel?
05Single
afraid of the dark
Lol i know it's a bit confusing. I think the buttons, switches, and guages all physically work, but none are illuminated.
ScottyBoy
Shreveport, La
Yes, that's what I'm thinking.
But we're they ever working? Or did they all suddenly Bo out at once? There is an illumination fuse for those dash lights. This can also be caused by a bad headlight , but it seems that's been tried already so that can be ruled out if the other headlight switches are DEFINITELY 100% working.
05Single
afraid of the dark
That's what I asked, if they went out all at once. I guess on my old silverado all the lights went out at once. they flicker on and off sometimes. still need to talk the new owner about it, he has no mechanical skills or experience so who knows. but all his buttons still work.
briannorris
