Header and exhaust Questions?
Tahoe_96
I have a 96 Tahoe LT that is completely stock. It is just a daily driver and I use it to toe my quads every so often. I'm already thinking about getting a BB tune. So my question is are there any benefit to replacing the stock headers I'm not looking to get long tubes just a direct replacement. And possibly a aftermarket muffler.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Generally it is the type of materials use, finishes, various thicknesses and quality of the build. Never heard any complaints about JBA ever.
DirtyBlackHoe
Thomasville, GA
I personally had a 1999 4wd Tahoe that had a manifold crack on it so I "upgraded" to Gibson shorty headers...I could not tell any difference in performance AT ALL. I would never waste the money or time to put shorty headers on a truck
T
Tahoe_96
Oh ok so i would be paying for quality
thats what I was affraid of....everyone says LT are the only way to go but then I would need new cats and extensions for my O2 sensors probably and X-pipe...just sounds exspensive
ezdaar
Chat Troll
Redneck central, Aka Houston
Shorts are a waste of time. Its longtubes or nuthing.
If you want alil more pulling power.
Look into a small cam and intake combo. Its cheaper and simpler to install, especially on a 96. Edelbrock performer intake and a cam cut for your needs.
Or swap your rear gears for some 3.73's if you dont already have them, If you do go to 4.11's.
Defiantly look into a E-fan setup.
Cold air kit, WITH enclosed box, Ebay.
Don't let anyone fool you, the ONLY thing needed for a functional CAI, in a enclosed box and a good flowing airfilter..
Here is a exhaust setup, Plug n play.
If you are currently 2 into one muffler setup, these below will convert you to a 1/1 muffler. for simplicity and driveway installation.
Header Y pipe
http://www.summitracing.com/parts/BIG-11504YFLT/
Mid length header
http://www.summitracing.com/parts/BIG-11504FLT/
These will bolt right up to any of the exhausts below.
Catback
Gibson, ebay
http://www.summitracing.com/parts/GIB-315516/
Flowmaster,ebay
http://www.summitracing.com/parts/FLO-17165/
Long tubes
Ceramic coated
http://www.summitracing.com/parts/PSM-72C2260/
Ceramic with Air injection
http://www.summitracing.com/parts/PSM-72C2263/
Painted
http://www.summitracing.com/parts/PSM-70-2262/
Painted with Air injection
http://www.summitracing.com/parts/PSM-70-2263/
Y-pipe
I am having trouble locating the Y pipe for LT headers that merge into one pipe for the catbacks listed above.
I know there out there, as My buddie has one on his gmc truck. He runs pacesetter LT's and a Pacesetter Y pipe.
T
Tahoe_96
Header Y pipe
Mid length header
Catback
Gibson, ebay
Flowmaster,ebay
Long tubes
Ceramic coated
Painted
Y-pipe
Yeh my stock exhaust is 2 into muffler then 1 out...and looking up through those edlbrock intakes just gets confusing I can never tell whichs is for mine since I dnt have carb or TBI
---------- Post added at 04:11 PM ---------- Previous post was at 04:07 PM ----------
I have been considering a cold air intake but Im affraid it will keep the check engine light on...cause on my 2010 Titan I just sold it was always on and that was with brand new K&N filter guess it had a sensitive MAF sensor
ezdaar
Chat Troll
My bad on the intake, I was thinking TBI setup.
There's no intake for your setup that I am aware of.
As far as the CAI, don't worrie about it with your MAF. It wont bother it at all.
SunlitComet
OBS Jedi-Do Good
same with headers to ez. don't think those will go on a '96. but at 18ga tubing i would not even touch then.
Also the k&n fipk will do no harm on the '96.
Tricky
Illinois
I was wanting to know the same as well and can get pricey, I just have Thrash mufflers on now until I get set up I want and or find something that will not rust as fast as flow masters. I had two sets on truck but rusted out being from Chicago with all the salt in the winters. Now fellas can you bolt up some used LT's or even the whole exhaust from another Tahoe 96-00? Mine is 00 Limited OBS. I saw some in bone yard but wasn't sure but it was during the winter and didn't want the hassle then of removing.
Sent from my iPhone 4s using Tapatalk.
T
Tahoe_96
your bone yard is better than mine the only aftermarket part I could find on all the OBS chevys they had was just a couple glass packs
992dr
Eastern N.C.
Another option is Thorley Tri Ys including the Y/mid pipes. Bolt up to factory exhaust with zero modifications. They come with all necessary hardware for the installation. Great fit finish and really woke up the Hoe.
Yes they are pricey, but, for a 50 state legal header with everything that you get, I think they are worth it.
Otherwise, LTs are the way to go.
Drewphil
