Have Bose...add more Bose?
BugginOut
I went to the pick and pull tonight, and came across a 2005 Tahoe with the Bose sound system in the back area. The cover was almost perfect (no better/worse than my existing blank), and it had the Bose sub behind it.
So I'm curious how it would work, I have the Bose sound system already, with my sub under the center console. This one is obviously one of those internal funky chambered speakers that the port points out the speaker grill. No visible speaker...
So the question I have is, how hard would it be to combine that sub into the existing sound environment? So essentially have a Bose sub in the front, and one in the back? Would I gain anything?
I looked at the pick and pull price list, and speakers are $15. lol. PLUS, if it's blown, they have a 30 day return policy.
drakon543
if you can find the sub input split that before the amp and direct that to a second amp for the rear bose amp and sub. wont sound good if you split the amp sub output too 2 separate subs. also if you cut that front sub box apart the sub will be inside the box. generally called a bandpass sub box where the sub is inside the box vs mounted on the outside of the box.
JPeter
