gearing
johnny_nap
i have a mostly stock 2001 tahoe i have a 6'' lift waiting to be put on and some 35's also but i have some worrys about my gearing, a couple of people told me that i wont any real power. What kinda gearing do i need.
J
johnny_nap
This is prolly a stupid question but the higher the number the better it is and where would I get them
KrautBurner
Bremerton, Wa
the higher the number the lower the gearing.
"4.56 gears" = 4.56:1 ratio (Transmission output : axle)
meaning your wheels will turn one time for every time the drive shaft turns once
going with "lower gears" (higher ratio) will give you better acceleration
but you will run higher rpm at highway speeds
going to a higher ratio axle will help re-gain the power lost by going with larger tires.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
4.56 to be safe. If you already have the 4.10s then just try them out and see how you like. Some run the 4.10s, some dont.
KrautBurner
Bremerton, Wa
So what would your recommendion be for me to do
check this out
http://izook.com/gearcalc.htm
do you spend much time on the highway?
I'd say to go with 4.10's (or close to it)
better fuel economy, lower rpm's (closer to stock with stock tires)
the calculator says 4.28:1 gears with 35" tires will be about the same as your stock 3.73 gears and 30.5" tires
if you plan on doing alot of offraoding or towing,
the 4.55/4.56 range will help you out alot
TallHoe 96 OBS
