gear ratios
jdpber
GOLD MEMBER
The America
Ok so talked with Nathan and i am going to post this here for now.
being that this pertains to OBS, NBS, NNBS i decided this location for starters
ok here goes.. thinking of regearing
now what information i am after is any of you that have regeared to lower gears..
with this said i am after information like what ratio you started with adn what you went to and a comparison of MPG, power gain, what was your RPM shift. aka what you cruised at before at a set hwy speed..
no yes i know the transmissions are different.. 4l60 4l80 the 6 speeds etc.. i know those trans ratios effect the MPG lets leave those variable out. if you simply tell me start ratio and end ratio and you you like and economy and power i can do the other side..
Start gear ratio
end gear ratio
opinions
tire size
how you like
rpm before and rpm after at a given speed
effects of fuel economy...
thanks all
The 'ER
Minnesnowta
I am also very interested.... Hopefully someone can answer these questions.
Da Kidd
same here im thinking about putting 456's in mine and looking for any info
jdpber
jdpber
GOLD MEMBER
The America
So no one has any information. Or links or other forum. Wow.
Drippin Wett
Another here interested! I have an 03 z71 and want to do the 4.56 gears. I've looked a pretty good bit on the internet, not much info out there for some reason. I'll be doing the switch after the new year before pulling the boat again. Mine is a slob with the 35's and the boat behind it.
Blazed
Accepting Donations
With the VVT and DOD I don't think something like 3.08 to 3.73 will affect much mpg. Obviously 3.08 to 4.56 is a completely different story I presume.
jdpber
jdpber
GOLD MEMBER
The America
Blazed stock the NBS is a 3.73 unless it was a factory upgrade to a 4.10
---------- Post added at 01:55 PM ---------- Previous post was at 01:54 PM ----------
Dripping wet. I totally know the feeling. Think about a loaded camper. I can't ever be in a rush when towing.
Blazed
Accepting Donations
I apologize I didn't realize I was in the gmt800 forum. Tapatalk gets me
I towed the boat last week for the first time with the "new to me" Tahoe, and holy cow! I will be regearing very shortly. I've talked to a couple people and I think I'm going to go with 4.88's and Yukon locking rear.
Everyone I talk to that has been regeared say its the best thing they did.
Sent while day dreaming...
Drippin Wett
I've been tore between the 4.88 and the 4.56; quite honestly for towing, I'm thinking just as well go with the 4.88's.
Juamgv
