Gauge cluster not functioning properly...
mrtrill
ATL
What r the chances....I go to a reputable audio install shop to get a wiring estimate (sumone broke in & stole my sounds). So, when they get finished, I go to my truck & notice when I crank it up, my gauge cluster didnt light up. Then I notice that my mileage was not showing. I go back inside & tell employee to come take a look. He tells me that he didnt mess with anything that would have caused it to malfunction. crazy thing is, the right cluster works, the back lighting will come on if I mess wit my interior light dial, but no mileage, no rpm needle movement, no mph needle movement, none of the warning lights @ da top come on (I know this because my abs system light should b on). flashers work. I dont wanna blame them but I aint into gettin messed over either. Do cluster gauges just fail like this?
blueflamed03
Oklahoma
ironic.......I say pull dash panel, take screws out just to make sure it's hooked up, etc...
mrtrill
mrtrill
ATL
oh i gotta turn a socket????
ha! lets c bout this.
---------- Post added at 05:47 PM ---------- Previous post was at 04:54 PM ----------
well I pulled it out as far as i could.
didnt notice anything unusual about it, (ofcourse iv never looked @ the back of it before)...service engine sign will lite up. still no
left info light n da box (battery/security). no rpm or mph needle movement.
guess ill just throw this in wit all the rest of the insurance claim.
m3mphi57
check the radio fuse under the hood worked with a friends 02 tahoe and when i got done messing with the radio his lights were out to couldn see reverse milage speedometer didnt work or ac i would check the fuses first
mrtrill
mrtrill
ATL
its a fuse under the hood, it happened to me a couple months ago.
I was hoping so, & ofcourse i would have checked but the mech @ da dealership advised me that its all on one fuse, so it wouldnt partially fail...
but even the gods can b wrong sumtimes...Ill check the fuses.
m3mphi57
Yea the dealership jus wants u to bring it in so they can get money for it thats all.
Im 100% sure its ur radio fuse
mrtrill
mrtrill
ATL
and u r right....15 fuse for the radio was da culprit.
:Handshake: u da man.
bottomline2000
Dallas, TX
My gauge cluster did that while being tuned, but the radio fuse had to be pulled in order to tune. I do believe Justin said the fuse is too small and put a 20amp fuse in it's place.
---------- Post added at 05:23 PM ---------- Previous post was at 05:18 PM ----------
scratch that..it was the cigar fuse directly to the right of the radio fuse that was changed to a 20amp fuse. If your cig port on the right doesn't work, that's why.
AdrienR
