Ok i don't have an answer to all of those inquires but let me tell you what i do know. yes the truck started every time i put a new pump in it . the only time it had a rough running issue was about ten minutes before the first pump quit. the 2nd - 4th where just working one minute and not working the next. ( they aren't stone dead just not enough pressure)
the injector leakage may be the culprit because while cranking the pressure is 35psi but when the key is released it quickly drops to 0
i will have to do the voltage tests and get back the results . hopefully tomorrow but there is a snowstorm here at the moment. thank all you for the info. i hope it works
---------- Post added at 08:24 PM ---------- Previous post was at 08:20 PM ----------
Can we assume that new new design of fuel is being used? As for checking the wiring the ground connection for it is on the left frame rail.
not sure what the new new design is . i have a 2 door tahoe and im pretty sure it has its own sender. Also i had the same idea that you did and thoroughly checked out that ground. i even ground it back to have a fresh metal on metal contact.
---------- Post added at 08:27 PM ---------- Previous post was at 08:24 PM ----------
ohh yea the filter is only about a year old but i bought one Aand hope to also swap that in the morning
