fuel injectors wrong spraying order...
fuel injectors wrong spraying order??
  • Yes, that's a real thing
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
hwhwhw
Has anyone ever heard of fuel injectors spraying in the wrong order? Is this actually a thing or is the dealership making this up??
drakon543
Is it possible yes probability of it happening without really stupid exterior intervention or someone trying to sabotage your truck. Since its posted in the 2000-2006 section each injector has its own plug. You would have to cut and splice more wire into most of them to plug it into a different injectors. You could also reprogram it for a different spray order but why? So in my opinion unless jesus came down and felt like playing a joke on you or someone really hates you. You have a different problem.
mizzouguy
Lake of the Ozarks, MO
If nothing else has been tampered with via wiring or programming, they are blowing smoke up your ass lol. If that is your only code there are other explanations.
02Lightning
Agreed with everyone else, what are they saying the fix is?
H
hwhwhw
They said that the fuel injectors were spraying out of order, and that they reprogrammed it for the correct spraying order...
02Lightning
Only way I could see that happening, is you had a tune on your truck. Other than that, I see no way of that happening.
drakon543
I happened to be talking to my buddy (gm master tech). I mentioned it to him and he laughed and said that doesn't make any sense.
Kpwweb
That doesn't just "happen". You would seriously have to try to screw up the fuel injector order!
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
That's a load of crap. The injectors fire based off the same sensor that the coils use to fire. P0300 just means that you have a misfire but the ECM is unsure which cylinder(s) it(they) is(are).
Must be a newbie tech at the dealer. I'd take it back and ask for a senior tech to look at it free of charge.
H
hwhwhw
They said it was fixed; I drove it for <10 miles and problem immediately returned; Engine shaking violently, random multiple misfires, flashing check engine light. They did not charge me for reprogramming the ECM... but another week it's still there.
H
hwhwhw
Now they said they contacted GM and the misfires are all on one side so they are pulling the header
JennaBear
Resident Ninja
San Diego, CA
Hope they said head and not header. Probably something simple like just needing an O2 sensor.
Sent from my fone.
H
hwhwhw
already replaced o2 sensors... They think maybe now stuck valves?
JennaBear
Resident Ninja
San Diego, CA
Possibility, but valves would be immediately problematic. Sounds like something involved with fuel correction.
Sent from my fone.
H
hwhwhw
I concur. It seems fine for a few miles. Then I get it up to highway speed 60-70mph, still fine. Then I do some stop and go driving and at the stops at idle the rumbling starts, and gets worse, until the entire engine is shaking violently and check engine light is flashing. I've already had the o2 sensors replaced, the gasket to the oil cooler replaced (huge oil leak) and now the ECM reprogrammed. And oil change and filter just for fun. Still getting the random multiple misfires. I am about to demand that they change spark plugs and injectors.
JennaBear
Resident Ninja
San Diego, CA
Spark plugs and injectors wont help.
Sent from my fone.
TallHoe 96 OBS
