front keys
the big blue bus
richmond, va
ive cranked mine but i only got 1.5 inches out of it and ive got this rake now with 2 inch block and id like it level. would keys be my only way thats not gonna cost me a lot of money. i havent maxed out crank either ive got good bit before im on droop stops bars are worn and old im pretty sure. i attached pic of the rake
99Yuk
Northern Ontario, Canada
No way! That's what I'm talking about! I love that rake! Today's trucks are level, that's so over rated. Go old school!
But big knobbies on. Skinny on front and wide on back on crager soft 8's. Put a cb whip antennae on the back of the roof. Grill gaurd and driving lights up front. Mmmmm, that's classic.
But if your stuck on leveling, then I hear ya.
One question though. If you started with a level truck, and the fronts went up 1.5", and the back 2". That would mean a 1/2" rake which would be barely noticable if at all. That pics looks like more than 1/2" difference. How did you acheive that? How much room is left of each key bolt?
the big blue bus
the big blue bus
richmond, va
ive got room left on bolt but it wont go anymore because of keys. i did a 2inch rough country block out back but looks like it gave lil more than 2 cuz the front 1.5 looks smaller than that. i might leave but i liked the level look. ill have to measuer from the frame to see how much higher it is in back tomorrow. the rake does give it a more truck look and ive got diesel bumper... and whip on back bumper haha. need me some tires
fyremanpat
Fyremanpat
after cranking the keys did you drive it around? you have to move the suspension a bit to get everything to set after tightening it.
fyremanpat
Fyremanpat
ok. you might have to crank the a little more just be careful and make sure the front axles dont bind when turning.
the big blue bus
the big blue bus
richmond, va
still 38.5 up front and 39.5 out back. the block did mroe like 2.5 was like 37 before. ill see if i can crank some mroe tomorrow. its not close to binding as it is now
bowtiefreak
No Quarter
Near Philly
Differently indexxed keys will allow you to crank more. You could try new bars or different bars out of a wrecked truck or something too. Typically on our trucks the keys give you enough to crank too much.
the big blue bus
the big blue bus
richmond, va
which would be cheaper? ive got to do all new ball joints and idler arm right now :/ then after that ill work on front
the big blue bus
the big blue bus
richmond, va
well mine being a 4dr mouts differnt in the back. it has these links which one has broken before and i replaced it with a new one. arent the truck ones longer? ill have to look at my freinds dads and his blazer and compare
im trying to get it looking like this
96ProCompTahoe
IN
from what little i have read the ford keys are for the NBS not the OBS. could try 3/4 ton bars. your supposed to be able to swap them in but i have yet to read up on it
sparg93
Expedition Tahoe
NJ
everywhere i looked it was showing the same diameter sway bars for the 1/2 ton and 3/4 ton.
However, I couldn't find the original part numbers or official GM stats...
sparg93
Expedition Tahoe
NJ
I was reading that uses keys causes premature wear on your suspension - any thought??
the big blue bus
the big blue bus
richmond, va
im not looking to max out... just ge another .5 to an inch of lift ot bring it closer to level. im going to stop by ford dealer and see if i can get the keys from them. with them i should be able to crank it and level it correct? after its level im replacing ball joints and idler arm and w.e else i need to up front
sparg93
Expedition Tahoe
NJ
add a giant set of Bull Horns to the front grill for that roughneck Texas look!!
<<sorry, just thought of a truck recently that i saw with it>> :)
mfinta
