Front caliper banjo bolt torque specs?
jyi786
I'm changing both front calipers on my 2012 Yukon Denali XL. Does anyone know the torque specs for the banjo bolt? I read that it's 30 ft. lbs. somewhere, and then 33 ft. lbs. in another place.
Thanks!
wsteele
Here are all of them, cut and pasted.
Brake Caliper Bleeder Screw - 12 N.m - 106 lb in
Brake Caliper Bracket Mounting Bolt, Front (1500 Series) - 200 N.m - 148 lb ft
Brake Caliper Bracket Mounting Bolt, Front (2500 Series) - 300 N.m - 221 lb ft
Brake Caliper Bracket Mounting Bolt, Rear (1500 Series) - 165 N.m - 122 lb ft
Brake Caliper Bracket Mounting Bolt, Rear (2500 Series) - 200 N.m - 148 lb ft
Brake Caliper Guide Pin Bolt, Front (1500 Series) - 100 N.m - 74 lb ft
Brake Caliper Guide Pin Bolt, Front (2500 Series) - 108 N.m - 80 lb ft
Brake Caliper Guide Pin Bolt, Rear (1500 Series) - 38 N.m - 28 lb ft
Brake Caliper Guide Pin Bolt, Rear (2500 Series) - 108 N.m - 80 lb ft
Brake Disc Retaining Screw (1500 Series) - 12 N.m - 106 lb in
Brake Hose to Caliper Bolt (1500 Series) - 40 N.m - 30 lb ft
Brake Hose to Caliper Bolt (2500 Series) - 45 N.m - 33 lb ft
Oldewing
Central Ohio
NEW crush washers too
but since you took the time to look up how tight, you prolly aready have new washers....
J
jyi786
Update: did the brakes yesterday, and I learned this the hard way (almost). I'm pretty sure it is 30 in. lbs. and NOT ft. lbs.
As I was torquing the bolt down, I felt it become super tight and then severely weaken. Since the head was in tight, I left it, but then I had this nagging suspicion that I didn't trust it, so I took it out.
Lo and behold, the new banjo bolt was semi-sheared and deformed from the top. Any further, I would have definitely broken it off in the caliper hole. Thankfully, I reused the old banjo bolt (with the new crush washers, of course), and this time, I started to ramp up the torquing instead of just going straight at it. The bolt almost started to do the same thing, but I backed off immediately.
All is well. New calipers and stainless steel hoses have been installed and tested successfully. Thanks so much again guys!
Geotrash
Dave
Richmond, VA
Bummer, man. That sucks. If it helps, I just re-checked the torque spec and it's indeed listed as ft. lbs. for the banjo bolt
Reminds me of one of my favorite sayings: "If you can't fix it, force it. If it breaks, it needed replacing anyway."
wsteele
That is a bummer. Makes me feel bad I looked it up in the shop manual. If you didn't have it, you likely wouldn't have ruined that banjo bolt (or worse had you not used your experience to know something wasn't right).
Like Dave, I went back to my source and confirmed it was ft/lbs. That is filed away in my head for the next time I am working on the brakes.
Walterpcs
