Friend's Esky throws EVAP related codes.
Pandabird
Finland
Just an acquaintance from whom I've bought some kickass second hand parts having a bit of trouble with his Escalade.
Says he's trying to figure out an EVAP problem. Has apparently swapped topcover gaskets, gas cap and one evap hose.
Says the computer asks him to "tighten his gas cap" followed by codes p0454 or p0455
Problem is a once in a while thing, can run for weeks without.
If it sounds all too familiar remember it's all new to me. Same year as mine.
Fless
Moderator
People's Republic of Colorado
EVAP test is done only on a cold start, with many other conditions being met: fuel tank 1/8 to 7/8 full, ambient temp within around 11° of ECT, etc. So not on every start, which means it can take a few days between attempts.
Failure can be caused by canister vent valve or purge valve malfunction, canister soaked with gas (caused by over-filling the tank), a defective fuel tank pressure sensor, along with others.
Mike shows the purge and seal test along with some good information:
CRN_25
