Flushing coolant system. Best way?
optimusprime
I’ve never flushed the coolant on my 08 6.2 Denali since I’ve owned it (5.5 years). Recently the heater hoses busted off and dumped a ton on the ground. I’m going to replace them and the upper/lower rad hoses and thermostat. Do I need to totally drain every last ounce of coolant out or can I just drain the lower hose and add new fluid? If I have to flush the entire system, what’s the best way to do it?
the best way is to let the dealer do it simply because they use a machine that vacuums the entire system out,
other than that just doing it yourself then park it on a slight incline with the nose down or jack up the rear a little, pull the lower radiator hose let drain out, replace the hose and point it nose up a little or jack up the front a little and refill with 50/50 mix. doing this allows all the air out.
my personal recommendation would be to also fill it with water a few times to push all the old coolant out, I also normally throw some radiator flush & water in it as well and drive it a couple days then flush it again.
others may have a different method.
alpha_omega
Michigan
x2 on what @Doubeleive said (both posts). If you’re not close to a dealer another option would be to pick up an “Airlift Kit” like this one.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Geotrash
Dave
Richmond, VA
I've had to replace the coolant in my Yukons a number of times for various jobs including cam swaps, new radiator, coolant tees, etc. I never had any problems with air in the system or anything else. Modern coolants are remarkable in their protective properties, and I've never seen any sludge or corrosion debris in any of my cars with modern cooling systems, even after hundreds of thousands of miles. I say put new 50/50 Dexcool in it, and send it. No need to flush. I'd be worried about residual flushing chemicals remaining in the system.
me51
Germany
When I changed the coolant in mine, I just took off the lower hose at the radiator and let it drain out. The service manual says there is a drain plug on the engine block, but I could not find it. The whole system is supposed to take about 17 quarts, and almost all of it came out if I remember correctly. Then I refilled it with a coolant with GM spec 6277M and bled the system which was not too difficult.
It is a very messy job though, make sure you have a kiddie pool or something similarly shaped to put under there to catch all the liquid.
O
optimusprime
CrackerJack135
