Gasoline will always be here in one form or another.
My brother in law - who loves to hunt, bought a fairly new vehicle a couple of years ago and went to Colorado to hunt and noticed that when he got out towards Iowa that all the gas stations sold the E85.
Now E85 by it's self is not a bad thing. You can run a tank or two of it in your vehicle with no problems. But as other forum members has said before, in the long run there is no reason to run it.
You only get about 50% of the energy out of alcohol as you do out of gasoline.
The research octane number might be higher, but there is no advantage to saving ten cents a gallon on fuel and getting 7 miles to the gallon less gas mileage.
Most new GM trucks already has a plastic gas tank, so the gas tank is not the issue. But the fuel lines needs to be stainless and the fuel filter needs to be for alcohol and the injectors also needs to be for the E85. The fuel filter should be a direct replacement for the one you presently have. Take the one out and put the other one in line and you should be good to go.
As I posted one other time today, you can use kerosene as a lubricant for the fuel injectors. 2 gallons per a tank full, about once every 6 months is all it takes to lubricate the fuel injectors. Alcohol, because it is hygroscopic, causes erosion on the fuel injector nozzle, as does most fuel injector cleaners.
Most fuel injection cleaners that are dumped in the tank also attacks the fuel pump and picks up any dirt that is in the tank and in the fuel lines and in the fuel filter and tries to push it though the fuel injectors. You are better off to do nothing then to use 99% of those products.
The computer in your vehicle will adjust fuel consumption to match the weaker fuel that the E85 is and it won't hurt the engine if you run a tank every now and again.
Back in the late 70's - early 80's, gasohol - which is basically E85 came out and the local gas stations sold it cheap. My dad bought lot's of it and within 3 years his steel gas tank rusted out on his 1971 Chevy Blazer and he had to rebuild the carb twice.. The owner of the gas station was rode out of town on a rail and the site where his gas station once stood is now a bank.
