Finally got the 2/3 drop done
millercreek
Texas
After putting it off for a month, my cousin and I decided to tackle the job of installing the Mcgaughy's kit. Took us about 4 hours, was our first shot at anything like this. The alignment was WAYYYY off, but luckily I only had to drive about 3 miles to get to a good shop. Anyway, these pics are all I have right now.
R.Beezy
Costco Member
Bay Area 510
Looks great bro. Are thos e 22's or 24's?
ya id like to know too. and what is your tire size? yours looks just right
im contemplating on maybe getting rims for the ride but seems like the hard part is getting the right tire size.....
Conor
"Bob's your Uncle"
Seattle, WA
Getting the right size tires is the easy part. Picking the wheels is the hard part. There is only 1 or 2 sizes to choose from generally depending on wheel size. With a 24" wheel, its either 295/35 R24 or 305/35 R24 unless you want rubber bands.
R.Beezy
Costco Member
Bay Area 510
for me, the hard part seems to get the right tire size. i already know what rims i want, now for the tires... i dont want them too thin or too thick. i definitely dont want "rubber bands" LOL
M
millercreek
Texas
Those would be U2-55 24x10's with 305/35/24 Kumhos. I know it's probably been metioned before, but I get a little bit of rubbing turning corners and stuff. Does this go away after a week or two, or do I need to trim some of the plastic in the fender well?
bigblue
Beaumont TX
looks really good, i think they are 22s, damn i couldnt imagine mine with a 2/3 drop :)
M
millercreek
Texas
They're 24's... and they rub a little, so if you have 26's you would probably have to do some major surgery in the fender well. I might have to trim a little bit. I will give it a week or two and if it's still rubbing, I will trim some of the plastic. Oh, and I cut my bump stops basically in half on the back, because they only had like 1/4" of clearance. The ride is a little bit more bouncy in the rear, but not that noticable. I think it sits perfect for a daily driver. I could probably still pull a small trailer with my motorcycle too if I wanted.
bigblue
Beaumont TX
where about in texas are you at? seems like i might have seen your tahoe before.
M
millercreek
Texas
I live between Abilene and Wichita Falls. I go to the metroplex fairly often though. I don't think you would've seen me around Beaumont though. lol
Modded
That Guy
295/35/24 is the best tire size toa void rubbing.
I sold some 24s with a +20mm offset and 295 tires to a guy on here and he does not rub at all, so with a +30 offset or higher you will be good to go.
I have +35mm offset wheels with 305/30/26 tires and a 3/5 drop, and it still rubs after a week of cutting, trimming, malleting, zip-tieing, molding, and just about all I can do!:emotions133:
M
millercreek
Texas
Thanks for all the compliments guys! I really appreciate it. Oh, by the way, those pics are the same day we installed the kit. I'm sure it will settle a bit. :cheers:
JPeter
