Failing motor?
DirtDigler
Happy Saturday all. My driver's side rear window only rolls down about 4 inches and is really slow. I pulled the door panel to inspect, didnt see anything suspect. Will a new motor fix it?
B-train
Most likely. I believe it's a whole actuator unit with the mounting bracket and all if I remember correctly. Should be an easy repair.
just hit the junk yard and grab one, there is 3 bolts for the motor, put a wedge in the glass so it won't drop on you when you pull the motor out.
I don't remember the bolt size probably 10mm though. you could just grab the regulator as well but the yard is going to charge more for it.
DirtDigler
DirtDigler
Thanks guys, I wasn't sure if just the actuator could be replaced or if you need to replace the whole enchilada. I'll just replace the whole unit. A little background info, the ride usually sits for weeks at a time with the back windows cracked. It looks like the one window stops at the same exact spot where I keep it slightly opened . Wonder if that had anything to do with it.
DirtDigler
DirtDigler
I got it to go all the way down by messing with the top cable. It wont go up though without pulling on the glass. I pulled the motor and it seems strong. I couldn't stop it with my kung fu grip. The area I circled seems to be the problem.
S33k3r
Dallas, Texas
Some things to consider:
1) lubricate the window
2) check your grounds
3) test the power getting to the window motor.
20 year old motos can really be hamstrung by such things.
Dh1280
