Esky Lights Installed
UofMZ71
ok so you cut both the tahoe wiring and the esky wiring? is there a way to connect them by buying other male/female connections and cutting those? The reason i ask is in case (i dont know why, maybe when selling) i would want to switch back to the factory set, and dont have to worry about rewiring all that stuff and just simply plug it back in...
Excon11
Excon11
Banned
North Dakota
The bottom piece where the harnesses meet
the ones closer to the engine stays the same. you only cut the tahoe harness from the tail light. If you ever would wanna make it back to stock simply de-install the esky lights and get the tahoes stocks and plug em in and it will work.
jdub5256
J-DUB
Frederica Delaware
so there is no body work that needs to be perfomed to make this work just a little bit of rewiring. if so i am going to do this
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
The 07+ housing mounting points for the Esky tails are the same as the Tahoe/Yukon so body work is not needed. It does take some effort to get them to work, but well worth it :imo:
KMeloney
And just to clarify, the shape of the Esky lights will NOT match the shape of the appliques above the tail lights. Some people care, others don't. If you care, you can also buy the Esky appliques to match the lights. I wouldn't call swapping those "body work," though, as you can swap everything in your driveway in 15 minutes.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
KMeloney is correct, there is a slight difference that will be noticeable if Esky appliques are not installed. Here are some pics from different angles of the shape difference when the Esky appliques are not used in conjuction...
Dukers
clean looking rides, and OP that looks great on ur ride, even though i know u posted this looong time ago just wanted to say its a clean lookin hoe
BadDaddy2003
