Engine Whine: As Troubleshooting Advise
skooter65
Gorham, Maine
First time I have experienced any engine noise; here were the circumstances:
Vehicle: 1999 Tahoe LT; 148,000 Miles
-Cold Started this morning, and By Cold, I mean sub-zero (-12 or so). Small amount of difficulty starting which I expected given the temperatures.
-While it was idling, I began to notice a slight whine/whurr coming from the engine (Upon further inspection, it seemed to be emanating from the lower front section)
-A minute or two in, the whine got progressively louder.
-At about 3-minutes, the whine was significant and the Check Engine Light Illuminated.
I killed the ignition and we took the wife's car to work. Haven't had a chance to troubleshoot so I figured I would check with the experts before tearing into anything this evening.
Your help/input is greatly appreciated.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i need the code that set off that light warning.
---------- Post added at 04:44 PM ---------- Previous post was at 04:43 PM ----------
without it is just a big guessing game.
Donnie Yukonie
Yates Caretaker
when my tensioner went out It made a whine like you describe but never threw codes ….
S
skooter65
Gorham, Maine
Well, Seems like it was just a strange set of coincidences. The whine was a failing idler pulley (Almost certain). the code was an O2 sensor heater circuit.
Changed Pulley, reset code and everything seems good to go.
False alarm!
CKendrick
