Engine Mounts 96 hoe
rican4lfe
Staten Island, NY
Stock full mounts or Energy suspension inserts??? By the way how much of a pain will be to get the inserts in???? also stock kit is about 50 energy 99 thanks in advance
rtaggart14
Not sure but you posted this in the 2015+ forum, you may get more help if you post in the correct model year section?
rican4lfe
rican4lfe
Staten Island, NY
Thanks. My mistake. Sunlit i see u recommend energy. How bad are those insert to get in??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i would recommend using a engine hoist or something that conforms to the oil pan to use a jack and only just enough to take weight off of it so as not to hit the dizzy. i would remove the finder splash shields as well to help if you need it for viewing and/or access. if you have good access and good tools you should have them both done in about 3 hrs or less.
