Engine Light "ERROR"
Someone
Kingdom of Saudi Arabia
Good day guys,
Engine light turned ON.
yesterday I checked and found this (see pic)
can anyone tell me in ENGLISH, what does it mean?
bad MAF sensor (mass air flow), I would check it and or the harness/connector or just replace it and your other issue's may go away, the maf can be the root cause of other problems.
p0101 is a bad or malfunctioning maf sensor
p00aa is a intake air temperature error (probably directly related to the maf)
p21aa is a throttle body position error or something of that nature (could also be related to bad maf)
b2aaa is a communication error with the scanner device used to pull the codes
It means the battery is weak or you have a bad connection like Wes said. After checking those two, then I'd venture to replace any parts.
No not bad. Easy things to check before spending money. If your battery is more than 2 years old consider just replacing it. A weak battery or one with a bad cell can cause all kinds of problems.
juniordaboi909
