Encoder motor
Kcbuckeye22
I've posted this already but I'll see if I can get some answers.
I replaced my 246 np8 transfer case in my 1999 tahoe and now I'm getting a service 4WD light and its stuck in 4wd. The selection lights for 4wd aren't working. I did not put the transfer case in neutral before removing the encoder motor. How can I get it to work properly?
I was thinking I need to put the transfer case in neutral and check the fuses. Do I have to reset the encoder motor as well or just the transfer case?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
putting it in neutral is not required according to the service manual. check fuse #2 t-case and #24 4wd on the fuse block near the drivers door.
K
Kcbuckeye22
After looking it over I found that I didn't have one of the speed sensors all the way plugged in. Transfer case shifts fine, however the selector switch for the 4wd isn't lighting up. Fuse still? Selector itself?
TallHoe 96 OBS
