Effects of front level Kit on suspension over time?
AZCreeker
Hello,
I am interested in putting on my 15 suburban a front leveling kit.
Apart from any increase on N.V.H, I read that putting a front leveling kit will affect the durability and wear out faster the suspension on my truck.
My question is for any of you guys that had a front levelling kit and slightly oversized tires for more than a couple years, have you seen any premature wear or anything that would make you reconsider if you were to do it over again?
thanks!
01Konvict
Boats n Hoes
Raleigh/SML
Nothing will wear other than upper ball joint and maybe bushings. All you need is some lift UCAs to correct it.
A
AZCreeker
thanks for your input!
Looks like it would be pretty minimal additional wear.
I am looking to put on 275 on my 18" wheels and lift the front 2" on my 15 suburban
NGAneer
NWGA
I've had my 2.5 TGC kit for almost 2 years and 305/55/20s (~33x12.50) for about a year. No ill effects thus far and I'm at 142k. If my ball joints wear out 10k quicker, big deal. It's a simple fix and then they'll be good for dang near ever.
Raider1
I planing to do the same setup you mentioned, but I have a 2013 z71 Tahoe. Have you done it? and if so is there any tire rubbing & could you post pictures please.
A
AZCreeker
not done still debating on what look I want to achieve
Raider1
Same here, still debating...
NGAneer
NWGA
My .02 on a Z71
2.5/1 kit
295/70/18
The same tires would clear easier on a K2XX because the wheel wells seem to be more forgiving. Sure you will probably have to trim, but cutting some plastic and a few whacks with a hammer to stuff you won't see is not a big deal in my mind.
Durobans
