flyinghigh54
I want to add another battery to my 2001 yukon. Where is the best place to put the extra and how do I connect it?
I have heard if you connect two 12 volt batteries then the voltage will double to 24 and ruin your electrical system. This true?
And I need to fix another problem is how to connect my amp properly to my battery... I have side post as i'm sure many of you all do to but I just kinda stick the wire on the bolt that is sticking out haha. I know this sounds sketch but even when I go offroading it seems to stay on. I can simply pull it off in a second though.
Thanks for the advice
If you have any links where i could educate myself on dual batterys that would be sweet
