driver door hang up 99 tahoe
domer94
northwest NJ
ive reas a couple of threads about the door hinge pins wearing out , but when i try to lmove the door up and down to test for play, it seems ok. when getting out of the vehicle, i have had to put a shoulder into the door. seems like its hanging up slightly on the pin or striker plate. any other ideas how i can remedy this? everything looks and feels tight.
Gzes
the drifting 2dr
Wichita tx
Mine doesn't move but I need pins. Have them but gotta put them in. If you look on top of the door it should show of the door is fallen
domer94
domer94
northwest NJ
i threw some grease on the mating surfaces in the door and its about 98% better. will see how long that lasts
kcb37
Wouldn't hurt to get pins. Should be $5 or $10 a side.
Could be wrong.
Dowsewashere
Is your door sagging at all? Do your lines match up? And if so just soak the mechanics with pb blaster. Then grease. For mine it worker like a dream.
YukonOfAlex
Same thing happened here. Eventually our door handle broke and we put rope around it to open the door and it opens like its brand new. I think its something woth the door handle not unlatching fully. If that helps.
chaingun427
OBS Mad Scientist
Mooreland, OK
I recently changed pins on mine and the door still sags a bit when closed, but opens and closes easily any ideas?
Sent from my SAMSUNG-SGH-I537 using Tapatalk
chaingun427
OBS Mad Scientist
Mooreland, OK
I thought maybe but they would both have to be as the door opens and closes like new
SunlitComet
OBS Jedi-Do Good
unknown at this time.
well it is not like it is forcing itself to be an inch off. with the momentum in a closing door you may not notice the little resistance.
chaingun427
OBS Mad Scientist
Mooreland, OK
It might be 1/4 off when closed for the body lines and it seems like the door is shut a little too far in as well
chaingun427
OBS Mad Scientist
Mooreland, OK
Door pins are new, ill be pulling the latch soon to clean it up and grease it, and inspect for extreme wear. If its too bad ill get a new one
95'Hoe
After replacings my pins, door still sags and can be a pain to open and close - any advice on this?
SunlitComet
OBS Jedi-Do Good
That would leave me to believe that the door locking mechanism is pulling it down when in the closed position. Ensure that the lock mechanism lines up with the striker as you swing it closed very slowly. Inspect all parts for wear or missing pieces. The striker is not supposed to be adjustable . I don't think the lock is either.
95'Hoe
Thanks Sunlit. So there is some wear on the top of the striker. I will keep tinkering with it!
veteran111
