Drain tranny to pull transfer case?
Nicolai8775
Put in a new monster transmission last week. I drove 900 miles to PA to see fam and I noticed the paper gasket between transmission tail adapter and transfer case is not doing its job. Can I get away with draining the transfer case and pulling it off to properly refinish the surface and get rid of the old gasket material like I was to rushed to do before? How much fluid is actually in the tail end of the transmission?
Bill 1960
Testing the Limits
That area should be dry inside. It’s either a leaking output seal on the trans or more likely the old input seal on the transfer case. I just experienced exactly this problem when a new trans went in. The transfer case seal was not leaking before, but it started leaking after reassembly. Old seals get stiff and may start leaking when the shaft is removed and reinstalled.
Axm1096
If there is fluid under the trans mout where can thst be coming from
Sent from my SM-A205U using Tapatalk
exp500
If the trans seal is leaking, it could drain 2-3 qts when u unbolt tcase. If fluid is dirty change Tcase seal too and hope you didn't wreck trans.
TexasTaz
