Door panel removal
haks310
Got LEDs?
SoCal
Need to replace the outside driver's door handle, seemssomeone tried breaking and broke it. Anyway what is the easiest way to remove the door panel?
Twenty4s
Banned
remove door handle bezel and 2 screws on arm rest the rest are just clips pry them off slowly and you can get at it.
the bezel has 4 clips 1 on each side. top, bottom, left, right. its easy i would start pulling door panel from the bottom.
mikeykey
I've broken some of them tabs off while removing the panel. FYI, gorilla glue works awesome at repairing broken plastic.
Just in case you broke any plastic........
briannorris
