Don't need an EMP to screw with electronics..
mikez71
Just saw this bulletin for fiberglass vans, where the wheel speed sensors glitch going under power lines, which screws with the ebcm..
It even shows voltage spikes/dips measured at the battery. I can't see the scale, but it looks like +/- 2V.
Has something to do with roof bows, I wonder if the spacing is critical. So they ground the bows with straps.
I wonder if the SSV's had bonding straps because of problems with radio equipment since all the wiring seems to cater to that.. (or lights)...
Marky Dissod
GM always added extra grounding straps & interference-reducing measures to PPVs & SSVs, but did not bother doing so for civilian vehicles,
ostensibly to save a few bucks per vehicle assembled.
mikez71
mikez71
Yep.. and I guess these are technically "bonding" straps.
I had to look it up, but if anything it potentially helps with ground loop problems.
Extra battery grounds maybe technically another ground? Not implying that it would induce a ground loop issue.
My assumption is that ground loops typically happen to something NOT grounded well to the battery, and having to go through a poorly grounded body part..
Got these 8" Napa 710899 straps on ebay (1 auction, sorry you'll have to find another seller).
They look like a better braid and crimp than the amazon stuff..
But not as nice looking as the 9" GM straps. (AI-10-0021REVA Ground Strap - which I can't find)
Jumpshot12
