Dome Lights stay on
Boyd
Hey all. My dome lights come on when I get in my truck (as they should) but then they won't turn off. When I stop the truck and get out, the lights fade and go out as usual.
Any idea?
I did replace them with LED bulbs but that was months ago and no problem until now.
Thanks to anyone that can help. Have a great Friday!
2012 Yukon Denali
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
I would try re installing older/factory bulbs and see if the issues resolves. LED bulb may have gone rogue.
Boyd
Boyd
That's a great idea. I'm sure I threw the old ones out but a fast stop at Auto Zone won't hurt too bad. Thanks for the help!
petethepug
Michael
SoCal
The lamps with the soft fade feature must have “code free “ bulbs with built in resistors. The low voltage pull of the led bulbs freaks out the dimmer circuit unless the resistors are in place.
Boyd
Boyd
Thanks Pete. I haven't even gotten around to changing the bulbs back yet. Do you know if they make an LED bulb with built in resistors for that application? I really like the bright light they throw out at night. Thank you very much for your time and help.
Boyd
Boyd
I finally got around to putting the stock bulbs back in. Still has the problem. Any further help or knowledge would be greatly appreciated. Dome lights stay on ONLY when I'm driving. They fade as they should when I park. Anyone??
Wolfbraid
Winston Salem, NC
Maybe a door switch? but I imagine you'd have a door open warning on the dash. Does the radio stay on until you open door?
JPeter
