DIY Alternator Replacement
lol, like how he skipped the "wiggled it" part, at least he didn't try and smack it with a hammer.
a rubber mallet works or if you have to bang on it otherwise use a piece of wood as the medium, the housing is cast aluminum and "can" crack if you hit it with a metal object
a screwdriver of the proper size works for lining up the bolt holes also.
O
OldSchool73
Alpharetta GA
Yeah the white lithium grease and some grunt got it in there. The left side went right in but the right side took a little more cussing to get it in there. Without the grease it would have probably been a lot worse.
Capybarbro
