Denali to Yukon swap
Nortex
I bought a Denali dirt cheap but hate the Denali front end. What's needed to do a Sierra or Yukon swap
Sent from my SM-S975L using Tapatalk
gtrslngrchris
That's an easy one. The grill, bumper and lights are all you need but if you're smart you'll keep the Denali projectors unless you have something better planned.
The Denali grill shares the same mount points on the core support and fenders as the standard GMC grills (I pulled my gmc grill mounts from a denali but run a standard grill) so you don't need to worry about that. Keep in mind if you that if you plan to keep your Denali headlights you'll still need turn signals as those fit differently in the different grills.
N
Nortex
Makes since thank you
N
Nortex
From an 03 gmc Yukon right
YukonXL04
The Riverboat
Arlington, TX
Heck while your at it. Do a 03+ sierra front end. Same amount of parts needed, just a different look
N
Nortex
I'm going to start collecting parts
05Single
afraid of the dark
X2 , do the 03 sierra clip, much better look.
N
Nortex
So same parts nothing extra?
05Single
afraid of the dark
Slightly different bumper and grille , but mount up same. Same headlights, fenders , and same hood for all 3... denali, yukon, sierra.
fiatdale
Houstons Best
Houston
This must be the first post in history where someone wants to convert a Denali front end to a Yukon. You should be able to quickly sell the Denali parts and easily make money after the swap.
MadDogDelpho
Texcellent
Texas
Iirc, the brackets for the 03+ sierra bumper are different so you would have to cut off the old ones and weld on new ones, which is why it's not a common upgrade.
fiatdale
Houstons Best
Houston
That's correct. The frame horn brackets are different. Not too hard to cut off with a torch & grinder. The new horns bolt on
05Single
afraid of the dark
Damn I didn't realize the horns are differnet. My buddy did his and never mentioned it. That's crazy, so horns in same spot just differnet shaped brackets ?
jackal78
