Denali front end noise
jericho121
Garden State
I am having a left front end noise. I will describe it as a light clicking as you your slowly roll (forward and backward) more as the suspension move lightly, then as you move a little faster you can hear a "squeeking" sound from the same side. Dealer already had change the outboard axle under warranty and the noise is still there. Just hoping somebody had the same problem and had it fixed. Car is still under warranty and my dealer is really good to work with it's just we cant really pin point the cause of the noise.
JML07denali
Could be front hub assembly. My right side just went out.
jericho121
jericho121
Garden State
The hub bearing was my initial suspect with the light clicking sound but what puzzle me is the squeeking sound I get on slow bumps. Was your symptoms the same? What year and mileage do you have? Thanks
JML07denali
My Denali is a 07 with 125k. Have the dealer check the CV axle, by your description sounds like that may be the problem.
mizzouguy
Lake of the Ozarks, MO
Could be two separate issues. Squeaking could be control arm bushings/strut bushings/sway bar. Clicking, if it didnt change from before to after the new cv axle, is probably the hub assembly.
jericho121
jericho121
Garden State
My control arms squeaked over small bumps, spray the bushings with some silicone lube. Solved my squeak.
Thanks for the inputs. I'm thinking the same two issues. Did the squeeking went away permanently after you lubed it up or you have to re-lube again?
mizzouguy
Its been a few months and hasn't come back. It took a few times of spraying them before it completely went away as well. I had just replaced my control arms and when i went to spray the bushings, I noticed an accumulation of (rubber?) built up on the bushings themselves. If yours are cracked or shot it may only be a bandaid but its worth a shot.
jericho121
jericho121
Garden State
What brand of silicone spray did you use
mizzouguy
I used crc brand spray silicone lube, marine grade because it's what we carry where I work. Honestly I'm sure any brand would achieve the same results.
08xldenali
I spent a fortune chasing a moaning squeak all over my front end - it was louder inside the car than outside, and inside regardless of what side I sat on, it sounded like it was coming from "my" side. Replaced CV axles, bushings, bearing/hub, ball joints, sway bar frame mounts & end links. Finally turned out to be inside of the magnetorheological shock absorber that I had already replaced once prior since it was leaking. These shocks are expensive pieces of $%^#.
jericho121
jericho121
Garden State
Just pick up the car from the dealer today. Mine is also the shocks on the driver side. The dealer change it today. They changed the axle and brake caliper on the same side trying to fix it.
mfinta
