Cylinder 5 misfire
992door
Greenville, NC
It only does it at 70+ mph. I have replaced the i replaced the plug wires and it still did it but it was running a little better. Today i replaced the spark plug and I will find out tomorrow on the way back home if that helped it if not what could it be
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
but you would have a 572 how could there ever be a problem when you have an engine as godly as that???
96ProCompTahoe
IN
572 sounds like a quick fix :) and if you nice i'll put it in mine first to make sure it runs good.
992door
992door
Greenville, NC
that is fine with me that way you could put the supercharger on it and test it out
knotty
mine is foulin the #5 plug and i cant figure it out ! lookls like we are in the same boat !
jayman8200
St Albans,WV
I have a 99 4 door lt, and mine was misfiring also, i replaced the wires and plugs on sunday and it fixed much of the problem but when i get 60+ it seems to still misfire slightly. what else should i look for into what it could cause this? im not sure if it is my number 5.
JPeter
