Custom headliner job!!! and its easy!!
crayfysh
Indianapolis
So for my sons 7th birthday I figured I would suprise him with another gift. He is really into camo right now and well I am a big kid lol...
The removal of the headliner is pretty easy, if you have a phillips screwdriver, 10mm socket and 1 torx bit, you can have the whole things out in less then an hour!!
You dont need to remove the old carpeting off the headliner unless it is sagging anyway.
supplies needed---
3 cans of 3m super 77 or equivilent spray contact glue, dont skimp on quality!!!!!
and a 11ft x 64inch piece of material, some people use old bed sheets!!!
spray half of the headliner with glue and half of the material at the same time so you dont ruin the whole project. and lay on the glue!!!! dont skimp or it will un adhere.
next lay the glued material down slowly smoothing out the material to get rid of bubbles and imperfections ( a second person is almost a must on this part)
next is glue the other half in the same process.
at this time score the material where there are any large holes ( ac vents, overhead council, speakers etc...) so the material will be slack and wont be stretched when it dries.
leave about an inch and a half of material all around the headliner so you can tuck it over to make smooth edges.
Let the headliner dry completly!!!
then trim all holes for speakers, grab bars, council, sunshades.
Now its time to reverse the removal process, take your time you dont want to ruin your hard work!!!
When all done sit in your back seats and admire your hard work!!! and feel free to show off!! :)
NathanJax
Vacation Nathan
Jax, Fl
good job!
I've done a few myself
xanatost
Lafayette, La.
Almost didn't see it ;) Good job! I been wanting to change mine out but wasn't 100% on how to do it. Did you leave your old headliner on and just go over it?? If you didn't how hard was it to get the old one off and cleaned up for the new one??
crayfysh
crayfysh
Indianapolis
Yes I did leave the old headliner attached. So far no problems... I'm waiting to see how the humidity will affect it now since its warming up! And thanks for the thumbs up everyone!!!!
Jon Valera
Long Beach California
While doing this project did you notice a way you can disconnect or bypass the rear ac controls and just use the front controls up top? I want to redue my headliner and also remove the rear controls but keep vents, any ideas or suggestions?
supplies needed---
View attachment 26819 View attachment 26820 View attachment 26821 View attachment 26822 View attachment 26824
Jon Valera
I am looking to re due my headliner in my 2000 limited but I also want to sound deaden it too! How much dead should I use? Was thinking 80sq inches should cover the whole thing, any suggestions will help thanks guys!
briannorris
