Cup Holder Part Number--
BobMc
I have an 09 Tahoe LTZ. The center console cup holder is basically useless with the small flip up doors.
I am searching for the part number for the non LTZ center console cup holder insert.
Thanks!!
Bob
BobMc
BobMc
Thanks to all!!
I have also received an email that indicates the the correct part number is 25793645--
So--
I'll check the numbers out and report back.
Bob
zach2011
Platinum Member
The numbers turn out to be the bezel, which includes the cupholders and all necessary parts for that console. So yes, that is the correct part number.
BobMc
BobMc
I now have the part in my hand.
Indeed, 25793645 is the correct number. It lists for $72.32 and can be had for much less thru on line sources.
The plan is to run 16 ga. wires, with an in line 5 amp fuse, up from the electric "box" just above the driver's left foot position, thru a drilled hole in the new tray to feed a double outlet recepticle to power a cell phone charger and GPS.
I also plan to install a "quick disconnect" junction after the fuse.
I will place a single outlet in the stock LTZ tray.
For daily use, the stock LTZ tray will be installed.
For trips, the new tray will be installed.
So--
What do you think??
Thanks!!
Bob
dheadv8q
Oviedo FL
I guess. My 07 Z71 has two outlets on the dash plus one in the console itself. I plug the cell charger in the one inside the console, and then drape the cord outside and close the cover. For the Garmin (its better than my factory nav) I plug it in the passenger side outlet. Is yours not this way?
BobMc
BobMc
In my 09, I have the same outlets.
They are RAP--Retained Accessory Power.
I wanted outlets that would come on and go off with the ignition key.
I agree--The Garmin is MUCH better than the factory nav.
Bob
2909K
Pittsburgh, PA
is this part number 25793645 for the black, or wood grain trim. I would like the wood grain trimmed one, to replace my useless doored one that I currently have. Thanks.
BobMc
BobMc
That number is for the black tray.
As far as I know, the only wood grained one has the flip up doors--stock on the LTZ.
Someone might post an update//correction to that statement.
Bob
048tahoe
