Crazycrew's 2013 Denali CCSB Build Thread
Soooooo, I just finished swapping out the BT struts back to oem struts with the coil relocators! Had bt struts set at 1.5“, went the full 2“ on the relocators. It dropped it about the other 1/2" I needed in the front.
Gonna get the alignment here soon!
If it's where you want, why are you doing a notch?
I’m upset that selfmadefab doesn’t have a nnbs notch. Their others are priced really good
Shoot him a message and have him see about making some :shrug:
What's your set up?
The shop that built mine did a new frame from the engine back so they could do a body drop with a stock floor. The frame is not as tall. Plus its bagged.
Yeah I bought it from a guy that spent a lot on it but I got a good deal. I have a build thread link in my sig if you want to see it. I don't wanna clog up your build. Actually I guess I already did, sorry!
C
crazycrew
Vacherie, LA
It's all good. I'm gonna check it out
C
crazycrew
Vacherie, LA
Ok, so now I'm no longer concerned about the rear bottoming out any more, I notice the front. Wtf are you guys doing? Seems like every bump. I hit I hear it rubbing the inner fender liners
On my Denali I mainly noticed it when turning sharp with my 26's and I cut some of the plastic out. My CC has tubs. You can check where it's rubbing at and go from there. You might be able to heat it up and bend it a bit. Or cut it.
Bob LaFord
