converter locking problem?
Asfalto
Northern Italy
Hi everyone! I need your opinions for this issue on my 1998 tahoe 5,7 4wd 4dr.
description: at highway speed, using the intermittent wippers, almost at every wip the transmission converter unlocks and suddenly locks again with the consequence of continuos rpm change. Many times also the cruise control disengages.
When I park the car I smell i sligth smell of clutch burnt.
No codes!
What can it be?
Jerky Arm Ape
North East Louisiana
I would check the wiring around the steering column going to the turn signal unit.
May be a faulty turn signal switch too.
The turn signal switch is an all in one unit which is why I'm referring to it.
Asfalto
Asfalto
Northern Italy
thanks, I'll check asap.
more notes:
- it happens either in the temporized wipper or single wip
- same behavior with the cruise off
- it started acting like this after I drove on a flash flooded road
OR VietVet
Multnomah Falls
Military
Willamette Valley
Flash flooded road meaning the water was really high and you drove through it and if so how high and if so and was high water why did you do that? Check for rubbed thru wire insulation in the same area that Jerky Arm Ape talked about but I still gotta know if you drove thru high water and how high up was it?
Asfalto
Asfalto
Northern Italy
The problem seems self-fixed.
I only had a visual inspection under the steering column and a check of the brake switch.
I also charged the battery..
:Insane:
msp2640
