Cold start grind
Krmnnghia
Anyone have this issue? I remote start my 2007 Yukon XL Denali from the garage and I get a slight grind right after the engine fires. Engine runs just fine even at -5 to 20 degrees outside right now but its just that 1-2 seconds after initial fire. Here is a youtube video of the exact sound on someone elses truck.
Thoughts? Thanks
PG01
Up here to the right
Sounds like starter gear not retracting fast enough because its cold. Technically i guess it could break the teeth on the starter gear and flex plate but its prob just catching. You can try some type of penetrating oil in starter where the gear is but it might be a pia to get to.
K
Krmnnghia
Thanks. Yah trying to get to the starter in this current climate...not fun :D
HiHoeSilver
Away!
Chicago
X2
67RS427
I just had to do mine for the same thing. Previous owner had a dealership install a reman starter ($340 part) @ 99k miles. I'm at 156k now and mine had issues like yours in the cold and started to mushroom the tip of the starter gear. Got a new AcDelco one for $140, I went with the Professional series. Cranks a hell of a lot faster now and starts immediately.
Danny3737
Does it do it when you start it normally? If not, the remote starter may still be sending voltage to the starter for a second after the engine starts.
K
Krmnnghia
Hmmm that is an interesting thought. It is now 40 degrees out and remote starting it does not produce the grind. Really only happens when it is well below freezing.
PG01
But have you tried key starting it in the cold to see if it does it? That’ll tell you for sure if remote or not
67RS427
Solenoid is going bad. Cold weather makes it harder to engage
chevync
North Carolina
My 03 escalade grinds like that every once in awhile, summer, winter etc. Its done it ever since I've owned it. (2 years)
13yukonNJ
New Jersey
Late to the party here, buy my 2013 Yukon did this the last two mornings, although it sounded much much worse than the video you posted. Yesterday was zero degrees here with a windchill around -20 and today was around 10 degrees with a -5 windchill. I've never encountered this sound before, and previously the coldest it's been when I started it was in the high teens. Next time I see the mechanic I think I'll ask him to grease up the flywheel on the starter, but normally it doesn't get cold enough here in the winter for it to make that noise.
jz57
+1. The starter solenoid is on the edge. 2 ways to fix the issue, replacing the solenoid or replacing the entire starter.
Before installing new starer unit or new solenoid, removing solenoid from starter, coating silicon grease on the plunge surface of the solenoid.
QUOTE="67RS427, post: 1197988, member: 58790"]Solenoid is going bad. Cold weather makes it harder to engage[/QUOTE]
X-ray Nerd
