Clunk in rear end
Eric GL
Hey all When taking off from a full stop the rear end on my 99 Tahoe binds up and it clunks. I have replaced the yoke and u joints and put in a locker rear end, still doing it. Driving me crazy.
Any help would be greatly appreciated.
OR VietVet
Multnomah Falls
Military
Willamette Valley
First: Welcome to the forum from Oregon.
I would be checking the leaf spring bushings and mounts and shock mounts.
Also, check the centering pin where the axle mounts at the spring perches.
1BADI5
DMV
Did you replace the pinion bearing?
exp500
How much play in rear yoke when driveshaft removed? Did the locker pattern well when Dychemed?
Welcome to the Forum from NH.
Pics, please.
You are already receiving some initial suggestions, and other folks will chime in, as well.
E
Eric GL
I replaced the whole suspention, new leaf springs shocks front and rear, control arms as well as all new steering components.
E
Eric GL
The the locker meshed well and the ring and piñon were in good shape. I will remove drive shaft and check for play tha Weekend.
Thanks to all for the help.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Would help to have that info in the first post. Don't cha know!
I guess it was a secret on that day you did the post.
RanchoTexas
