Climate Control Issue
Davis25
Minnesota
I purchased a 97 Tahoe a few months ago. One thing I noticed when I bought it was, no matter what setting the climate control is on, the heat/air always comes out of the dash vents. Any idea what this could be and what to look for?
I replaced the climate control board and still does the same thing. The A/C does NOT work, but I don't know if that has anything to do with this issue as I believe that this problem may be the compressor.
Thanks!!!!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
The mode motor on the hvac assembly would be next if you replaced your control head already. As for the A/C your charge is probably low.
justinp95
TX
Did you fry it installing it? Haha. They are very touching. Ive fried a few messing with my deck. They go up in smoke.
D
Davis25
Minnesota
I don't believe that I fried it, although I cant be 100% sure.
I found what I think is the mode motor. Two of them, one, under the dash above the accelorator pedal, and the other under the dash and glove box, behind the blower motor.
Does anyone know which one it would be? My research tells me that there is a "Auxillary" and a "Main" mode motor.
Thanks!
drod1977
new jersey
climate control
Im still a newb here, i wish i had more time to be on this site. Ok anyway it's for sure the one near your gas pedal.I had the same problem when i first got my tahoe, i still have'nt replaced my motor i just turn it with my hand lol.
Monstar_est87
City of Angeles
Thanks!
Yea those are the blend door accuators... Have you tried pulling the them off while still connected and turning the selector knob..? Its only 2 screws holding them in and U'll B able to see them turn, if they do work that is...
TallHoe 96 OBS
