Checking opinions with this fit without rubbing?
HD4
NJ
Have 2013 Suburban LT 4x4 has max tow package no rear air ride. I have one of the adjustable eBay leveling kits for the front it's the billet spacers you add. can raise 1 inch , 1.5 inch or 2 inch. I am thinking of going 1.5" with the new 20" wheels I have with 305/50/20 Nitto terra . From what I have read on here it seems I will be ok with no rubbing? If I go 2" will the front be higher Cali lean?
felixgun
Lafayette, LA
I had a 2.5/1.5 on my avalanche with those exact tires and it still rubbed a little but I think.
H
HD4
NJ
Well that's disappointing to hear May have to go another direction then
H
HD4
NJ
May go 285/55/20. Seems to be slightly only larger then stock on the trusty tire size calculator. anyone running this setup with 2" level?
Yukon11
Arkansas
I'll be finding out this week. Running the rough country 2" with 285s...albeit I did order some .75" spacers for the rear. I suspect it would rub at full-lock if off road, but should be fine for all on road purposes. I don't drive around doing full lock turns enough to worry about it too much...we'll see!
Yizzo88
