Changing the battery
Mgyver1
Las Vegas
Do you have to remove both of the fender support brackets to replace the battery?
---------- Post added at 12:59 PM ---------- Previous post was at 12:14 PM ----------
Disregard, the answer is yes.
Pretty easy too, all you need is a 13mm with some extensions (to reach the lower battery tray support bracket and battery hold down block) and a 8mm to undo the battery terminals.
04ctd
Charleston SC
I took the off the side brace (corroded)
i took the water jug out (radiator overflow)
two 10mm, use a long extension, battery pulls straight forward & out
just FYI in case someone finds this thread.
Korbin_A
