We have a 2007 Yukon XL with a 5.3L engine. Recently, the check engine light came on (error codes P0341 for camshaft position sensor, P0335 for Crankshaft Position Sensor Circuit, and second P0335 for Crankshaft Position Sensor Circuit). A few days later, the Stabilitrak message came on followed by the Low Power Mode - we could barely limp across a parking lot at this point.
About 2 years ago, the Stabilitrak message pop up followed by the Low Power Mode, and it turned out to be the passenger side catalytic converter. This truck had an oil consumption problem that was fixed by the dealership several years ago, and I don't believe that's a problem any more. I never could figure out how a catalytic converter would impact Stabilitrak, but it was gone after the catalytic converter was replaced. I'm thinking these other problems are causing this, but I'm not certain. I've physically checked the cam position sensor and wiring as best as I can, and it looks OK. Trying to get my multimeter leads around either of these sensors to test seems like a difficult prospect. Should I just try to replace these? Any suggestions? Thanks
