C0242 ghost code
ukrkoz
Auburn WA
07 Tahoe LT
Pass side air shock pooped and I replaced it with the new one.
Immediately I had ABS/traction off/service stabiulitrack warning.
Truck drives fine. Like - real fine
I hooked up my ABS scanner and it pulled C0242 code.
Deleted code, rescanned the system, scanners says - no DTC stored, scanned several times - same, no DTC, and I scanned for Tahoe specific ABS codes - warning is still there. Severla restarts didn't change anything.
Any ideas? I don't have a fancy scanner to get in depth scan. And buddy, that has one, is closed.
Truck is daily driver, I don't want to get caught with dreaded reduced performance situation, like I had about a month ago because of the bad throttle body. Yes, new throttle body, Hitachi and MAF about a month ago.
Thank you
U
ukrkoz
Auburn WA
Fixed it
Rescanned again, C0242 was gone but rear wheel sensor code popped up
I knocked off sensor plug when removing or re inserting top shock bolt. Those, who did it, know, how tight the spot is and sensor connector is right under the bolt.
Rides VERY nice now. On the old shock, entire air bag dropped down on the shock, knocking on the lower mount on every bump. C-clamp at the bottom of the air bag housing came loose and it all dropped down.
This is what the good shock looks like and, below it, bad one:
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Yea, like @Fless said and I would have said, go back and check what you JUST DID. Most of the time, that is where the problem is. Hell, even after all my years doing this, I have done things with my big hands that created another problem and went back and found. I have learned to check and double check as I reassemble. This is after doing a heater core years ago and had to do a 1/2 disassemble to find a heater door cable/connector that I messed up on.
dizhai
