Brightness of A/C controls
unusualtomato
It seems like my 07 tahoe has a tough time telling whether the display on the air conditioning should be bright or not so i can rarely see the temp during the day. Anyone know why this is? I can see it toggle between bright/dim during the day when it shouldnt be
Anything blocking or obstructing the light sensor on the dash? Did you adjust dimmer switch? If so, it just might be time for a new module. There might be an internal code that you can pull with a scan tool that can read BCM codes.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I have the same issue off and on. Sometimes it's bright, sometimes you can barely see it.o_O:(
JPeter
