Brake upgrade questions
Monstar_est87
City of Angeles
Im thinking of upgrading to the 3/4 ton calipers... but im not sure if the upgrade applies to 2wd tahoes as well... I see it on tons of 4x4... Also will I have 2 run 3/4 ton pads or stay with 1/2 ton pads..? I just gotta get all this for the right price and ill be in business...
So heres the math:
3/4 calipers+ powerslot rotors+ pads?+ SS brake lines =
stop on a dime wit 9cents change
I appreciate any feed back...
UPDATE!!!!
Ok so first off I didnt go with the powerslots bcuz I could bare spending $160 ea. on rotors, and the SS brake lines I read somewhere (i think by sunlitcomet or 99yukon) that they didnt make much differance at all so decided to hold off...
R1 concepts Drilled and slotted rotors/ 3/4 ton brake calipers/ Hawk high performance 1/2 ton pads
I couldnt b happier with the Hawk pads smooth braking and very low brake dust
Amazon caliper 35000 express GVW 8600 caliper, I painted red
. And my stock caliper
Rotors installed without a hitch
Everything installed... As of 4/7 I've been using everything for 5 days now and very noticable difference... I am very happy with the install...
retorq
Kingman AZ
LOL The only thing that is gonna make your Tahoe stop on a dime with 9 cents change is a hydroboost setup. New rotors, pads and calipers will improve it but not to that extent.
I am pretty sure you run 1/2 ton pads with the 3/4 ton calipers.
retorq
Kingman AZ
Yeah combo would be a killer setup. I think I'm gonna do the hydroboost cause I have some clearance issue with my Vortec intake's vacuum source and the TBI fuel lines. :(
Monstar_est87
Monstar_est87
City of Angeles
Either way we decide to go I think we're looking at about $700 bones, And the combo $1400, Atomics rear disc suggestion $1050... So looks like I got sum saving up to do...
Monstar_est87
Monstar_est87
City of Angeles
Haha no problem... Im in no hurry either... I really just need 2 get the front done but figured mite as well throw sum upgrades while im at it...
retorq
Kingman AZ
I did some research ... if you are serious about the hydroboost setup on a 95 the 1 ton 2wd trucks had that as an option WITH REAR DISC BRAKES. You can get everything you need factory from the local autoparts store ... didn't check into other years but I bet they are the same way.
AtomicHoe094
Atomichoe094
cleveland, OH
if you want the hydroboost parts numbers for OEM shit, here ya go :)
gathered them up a while ago and been sitting on it
Hydroboost kit PN 178-578
master cylinder PN 174-722
steering box PN 36-0517567
power steering pump PN 36-517138
Hydraulic line from pump to booster PN 36-365470
Hydraulic line from booster to steering box PN 36-365480
Monstar_est87
Monstar_est87
City of Angeles
Would any one happen to have part numbers for the power slot cryo rotors..? Keep in mind The Limited is a 5 lug...
johnsonwillie199
