brake conversion
blue99tahoe24
bout that tahoe life
joliet il
has any one here done a rear brake conversion from drum to disk brakes and if so how hard is it to do? thanks
SunlitComet
OBS Jedi-Do Good
unknown at this time.
vacuum booster is replaced with hydraulic unit powered by power steering system. Looks similar to this.
96ProCompTahoe
IN
i have a kit in the garage that didn't end up fitting my rear end. up for sale on the cheap!
sparg93
Expedition Tahoe
NJ
+1 on sunlit's comments.
Rear disc conversion is only for looks. If you want to improve stopping power start with high performance pads and if you want more, research the hydroboost conversion.
Your Tahoe utilizes a "vacuum" system to power assist the brakes. Heavy Duty (3/4 ton & 1 ton) models chevy made came with hydraboost instead of vacuum. Hydraboost systems tap into your powersteering pump.
From what I've read, hydraboost setups are the best bang for the buck and are a significant improvement. However, it takes time and research to do this the right way...b/c errors with the install can cause the brakes to fail.
For new AC Delco parts, you're looking @ $700+. Some guys will just take used setups off of heavy duty trucks and use that.
AtomicHoe094
Atomichoe094
cleveland, OH
i did the swap with an SSBC kit. kind of a pain in the ass install but wasn't tooo bad. I needed to fabricate a few things since it wasn't actually designed for my year.
Heres a few shots. next brake upgrade is slotted front rotor and a good set of pads.
---------- Post added at 05:59 PM ---------- Previous post was at 05:58 PM ----------
alsoo.. these ppl have a sick deal on brakes..
http://www.performance4trucks.com/special-deals.aspx?deal=1664
blue99tahoe24
blue99tahoe24
joliet il
looks good atomic. 96pro comp u got a rear drum kit or hydraboost got any pics of it thanks guys for all the info to i gotta do something about these brakes i think my exhaust busted or melted my brake line because brake fluid is all over my rear end leaking all over the place easy fix or what???
96ProCompTahoe
IN
if your brake lines were leaking that bad you would have no brakes.
its a Stillen Rear Disc Kit off a 99-00 Escalade (bought it off a member from the old forum) i have the smaller of the two drum sizes offered in the 1500 OBS SUV's. the kit is for the larger drums. I can send you pictures with measurements if you want to double check you axle tube flanges. Also the E-brake cables are for a 4-door.
Kit is used and needs a set of pads and could use the E-brake cables replaced (IMO) at some point but they are not froze up.
Kit retails for around $1500 with the stainless brake lines, I just want to recoup some of the money i have in it. looking to get $300 out of it.
blue99tahoe24
blue99tahoe24
joliet il
i have no brakes made it home on hopes and dreams lol brake fluid i dripping out like water from the rear brake pedel hits the floor and the parking brake light comes on. i want the brake kit from ya but i have to check my funds brake line situation came up and can u send me the pics and measurements email is [email protected] thanks
blue99tahoe24
blue99tahoe24
joliet il
ur rite on that one sunlit
---------- Post added at 07:46 PM ---------- Previous post was at 07:46 PM ----------
im in the same boat lol
AtomicHoe094
Atomichoe094
cleveland, OH
thanks man, look for the used kits like procomps. its not worth the 1500 bucks they start at new. if i didnt buy it cheap i would of never of bought it
AtomicHoe094
Atomichoe094
cleveland, OH
hell yea it is... in most cases you can reuse your old brake lines on the rear axle if they are in good shape. youll need to re bend and maybe cut a little off of them.
Usually Stillen/SSBC use factory OEM parts from different cars to make it work. This way the parts will always be there when you need them. IE brake pads, rotors, etc etc.
I know my SSBC kit uses some Volkswagen brake calipers or 80s ford car calipers..
mfinta
