blue bus version 2
the big blue bus
the big blue bus
richmond, va
Progress is looking good dude! I might have missed it, but how much lift are you planning on going with?
trying for around7" if it will end up that tall no tellin.. the bl is long off and on my buddys 2dr now so it will be all suspension. 52" springs up fornt and probably shackle flip rear with the 2inch block now to get it all same height.
this is a budget take so progress isnt that fast. i look around and find deals and when i have axle done and spring hangers ill tear it down and get axle hung then finish the small details. spring is goal to do the swap but if progress moves faster than planned ill do it sooner
the big blue bus
the big blue bus
richmond, va
got diff cover off a dodge this week and stock tie rod set up off a k10
you can see the housin in picture too somewhat all painted and brackets cut off
the big blue bus
the big blue bus
richmond, va
orderd the steering kit and got my open front carrier yesturday and some u joints. chromoly shaft should be here tomorrow then ill start reassembly after i swap the carriers
the big blue bus
the big blue bus
richmond, va
swaped the carriers out today and put all the axle shafts together yesturday at work. orded the shackle flip and pitman arm tonight. axle should be ready here not to long. waiting for warmer weather to tear down
the big blue bus
the big blue bus
richmond, va
so the front axle is prety much done. just waiting on 5 more studs and to cut and weld the tie rod. got the hangers last week too and the exteded ss brake lines.
traded the aluminum 16 inch eagls i had for the front and rear from a ld 2500 so i got the 6 lug 14 with 4.10s to match my front d44. probably going to sell the front diff and the 4.10s i got for the rear 10 bolt.
Gzes
the drifting 2dr
Wichita tx
What happened to the build? Is it done? Still getting built? Idea get tossed?
vsaravia
