Blinkers - Interior Lights - Not Working, Need Advice
PandaClaw
I will try and keep it short but I am having some electrical issues and am hoping the community can shed a little light (Pun Intended) on my issue. 2013 Yukon SLT - I had VLeds switchbacks installed for quite sometime and I was starting to see them behave odd or out of sync so I needed to troubleshoot which part of the system it could be. This involved switching from side to side the adapters, control box, resistors, and bulbs. During this process something shorted and blew both parking light fuses.
I replaced the fuses and they blew again. I took the Led system out and went with the old bulb. The bulb will light up when the parking/low beam lights are on but will not blink. Inside the blinker starts normal then goes to hyperflash mode but the front lights don't blink. Furthermore, Now my interior lights do not come on when I open the door and my back blinkers do not work either. I also have Escalade replicas on the tail lights that I never once had an issue with. I am hearing it could be a BCM possibly?
If I can't get this sorted out I am going to put everything back to stock and try an cover my tracks then bring it into the dealer and hope for a warranty repair. (HID's headlights and fogs, Tailights, interior leds, etc.)
Any thought on what I can check???
PandaClaw
PandaClaw
I found a couple additional fuses that were blown on the inside panel. Changed them and I am back in business. All told it blew about 5 or 6 fuses. Sending the whole kit back to Vleds for testing/warranty.
Docpreston
