Big Problem!!! HELP!!
elwilli87
Lexington KY
so i had i big problem with my ecu where a wire was burnt and caused my truck to blow a fuse every time i put it in to drive. well i got that problem fixed but now for some reason none of my dome lights work nor does my cruise control turn on. is there a fuse i should be looking for here?
03YukonNH
Manchester, NH
For your dome lights, make sure the dome override button isn't pressed in. It sits next to the dimmer switch to the left of the steering column. But like the person above stated, check the fuse panel on the side of the dash and under the hood.
Ralph Turner
