best place to pass through firewall
madmanjustice
going to try and install my light bar on the front of the PPV, What is the best place to run the wiring through the firewall for the inside switch?
wjburken
Eastern Iowa
I would look at the various grommets that are currently in the firewall and see which one has room for your wires. There are a couple larger ones behind the drivers side of the dash.
just go thru right where the main harness goes thru it has a big rubber grommet around it. a small wire you can just push the grommet aside go around it, thicker wire may want to just make a hole in it and feed the wire thru.
there may be a small spot just to the right of it also
Durobans
