best place for wire through firewall?
pavemen
Modesto, CA
i have not looked yet, but where is everyone running battery cables into the engine compartment? i can drill holes, etc, but if there is some factory hole/grommet/etc that will work I'd prefer to use that. I'd like to run a single cable from the battery to a distro block/relay setup under the center console.
Wont need to be big cable, just some 8-10ga for small power use right now.
Crazy-Jbird
there should be aa rubber gromet near the brake pedal you ccan run the wire through.
CKendrick
